Re: Bosch WFX2467GB/01 – skipping to end of program
Thanks Firestater.
Been out to this this morning and is looking like a board fault – It does not select any programes and displays just 1200 spin speed and zero mins left what ever you select.
There was also no supply to the door lock – pump, heater checked out ok motor ok apart from 2Meg insulation res on armature/brush which presumably from carbon dust build up but little lower than I would have liked to have seen.
But looking like a board fault – unless anyone else knows better?
Not brave enough to strip these things tho 🙁
Mick
