Bosch wfx2867gb/10 spin fault
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch wfx2867gb/10 spin fault
  • #81767
    Salamander
    Hi I have an unusual fault in that on a rinse cycle the machine will try to spin at high speed for a second then stop for 30sec or so and repeat i.e. it is attempting to go to fast with water in. Any thoughts? It had new brushes about 6 months ago
    #417643
    Salamander
    Re: Bosch wfx2867gb/10 spin fault
    Actually it just seams to flick over and stop each time the motor goes
    #417644
    Check your drain filter is clear and that the machine pumps the water out within 60 seconds or so.
    #417645
    Salamander
    Thanks for the tip, pump/drain is fine. I’ve taken the brushes out and cleaned the armature and
    It seams to work now but I have a feeling that won’t be the last of it
    #417646
    Salamander
    Well it didn’t spin properly so back to square one
    #417647
    Salamander
    Some times the motor will run as normal, others it will just run for half a second then pause till the direction change. Many years ago I used to work for a rental company repairing washers but I don’t remember a fault like this and I can’t think its worth buying a new timer unit to find out if it is that.
    Anyone have any thoughts?
    #417648
    neilsukwg
    As Martin said I would check draining action first.
    With water in machine, choose drain only
    How long does it take to completely empty?
    You will hear a distinct difference in sound once it is completely empty
    A machine that is draining normally will take 15 to 20 seconds
    #417649
    Salamander
    Hi, I thought pump too but it pumps out fine and the fault occurs during the rinse/wash cycles also when water should be in the drum
