Bosch WFX2868GB/20 stops/flashes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFX2868GB/20 stops/flashes
  • #85449
    smeghead
    Odd one this, about 15 minutes from end of cycle the timer display flashes on & off a number of times then goes dead.
    After setting a different programme it will work again till 15 mins from end, then same thing.
    Checked today , wiring, lock etc- no fault found.
    Does this ring a bell with anyone. Thanks
    Clive.
    #428642
    Re: Bosch WFX2868GB/20 stops/flashes
    I would think it has got to be a ribbon connector error between the display and the display board or the display module itself?
    #428643
    smeghead
    fair comment Martin, but customer says it’s always 15 mins from end, if it’s a ribbon cable , it would occur at any time during cycle surely.
    anyway thanks for your input!
    #428644
    wizard
    The only thing it does different at that part of the cycle is to energize both inlet valves for fabric conditioner dispensing. Just a thought. Wiz
