Bosch Wfx3267gb/10
  • #72611
    ddirect
    Been to call today burnt out pump (not original bosch pump)
    Replaced pump but still no empty,
    Their is power to the pump,so would i be right in assuming there is a module problem caused by the burnt out pump?
    Darren
    #385041
    Re: Bosch Wfx3267gb/10
    ddirect wrote:Their is power to the pump,so would i be right in assuming there is a module problem caused by the burnt out pump?
    Power to the pump yet it still doesn’t work, how come? Or maybe you’ve only got a live feed and no neutral? The module is switched on neutral by the way.
    #385042
    ddirect
    Thanks Martin for the reply, thats why i was presuming that the problem was a board fault just needed confirmation and wondered if it was a known and fixable problem or new board altogether?
    #385043
    The latter I expect. Take it out and have a closer look, especially for a blown pump triac I would imagine.
    #385044
    ddirect
    Had a look Martin nothing really obvious, apart from some small heat marks on the plastic that sits above what is probably the pump triac like you suggested.
    Thanks for the input
    Darren
