Bosch WFX3268GB/23 drum same as WFLI2440GB/14???
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Bosch WFX3268GB/23 drum same as WFLI2440GB/14???
  • #56944
    whiskeyjack6058
    I have in my workshop a Bosch WFLI2440GB/14 integrated washing machine that is in for a bearing repair. After a pig of a job removing the tub and splitting it apart I have noticed that the drum shaft has a pitted dent on it right where the drum seal is seated.
    In my lock up I have a Bosch WFX3268GB/23 that has a blown motor and good drum and bearings. I would be very interested to know if the drum is the same as the one I have in bits so I can continue the repair for my customer. I know I could find out by taking it all apart but I would rather avoid this time consuming pain of a job to discover its different. Had a look on connect to see if I could compare them. I found the drum for the WFLI2440 machine but not the WFX3268 one.
    Would love to hear back.
    Many thanks,
    Rob.
    #329337
    Re: Bosch WFX3268GB/23 drum same as WFLI2440GB/14???
    Can you not compare them HERE
    #329338
    Turbo
    They are different 😥
    You can double check on the bshappliancecare web site.
    Graham
    #329339
    whiskeyjack6058
    I didn’t know about the Bosch E-Shop till now.. They are different part numbers..
    Thanks guys 🙂
    Rob.
