My integrated machine does not display fault numbers but has flashing lights which I cannot interpret. (I cannot find this machine on the website.)I unfortunately did a wash with a thin bib caught in the door. It carried out the normal wash but started to beep when doing the fast spin. I turned it off, waited and opened the door using the emergency red tag. I put the dial to 30, pressed start and it started beeping again and instead of the wash light coming on, the Spin and End lights flashed constantly as did the 400 spin light and the door locked.It also was beeping. I rang Bosch who suggested turning the electricity supply off for 30 mins to see if it reset but it has made no difference. Is there any way I can reset the programme or is there a fault?
I suspect as a result of the bib stuck in the door, water has leaked down the front and into the base tray. Power off first, remove bottom inspection panel and check for water.
Thank you for your helpful reply. The machine was still sounding the alarm after 24 hours but 48 hours later it has reset itself and is working normally again. It could be that it got damp and has dried out. Highly relieved.Very useful forum.
