Hi,customer reported washer did not complete cycle an display blank,I traced power into the front fascia board,so ordered a new board,fitted and still no display,i see you have to program board to new washer,but in info the start button should flash which it doesn’t,just to add to the woes,there is signs of a mouse nibbling the odd wire,but no real damage I can see,any ideas would be great,cheers
If any of the smaller components fail on the 5v system , it can cause the display to blank out. Try disconnecting the 3D sensor , pressure switch etc one by one to see if the display reappears .
