bosch wiw28300gb/02
  • #93140
    HotDog
    Customer bought this at auction door is stuck couldnt get it open pulling release lever, had to go in from top and release it when you select spin and press start door locks then after after about 10 seconds the display jumps from 13minutes to 5 minutes if you then press start pause again you hear as slight click from door lock but does not release tried new lock no diffrent so i am now thinking power module on the bosch sight it says £90 not programmed does this mod need to be prog anyone out there know
    #453325
    Re: bosch wiw28300gb/02
    don’t know what you mean Bosch site gives prices for both programmed and unprogrammed modules
    HotDog
    dont know what bosch site i was on but only showed not prog mod £90 i have found prog mod £113 curious know how they program a power mod would it be done via a laptop
    #453327
    http://www.bosch-home.co.uk/customer-se … pare-parts
    this is where to look for gen parts prices and numbers
    yes I agree if its programmed onsite would have to be done by laptop
