Bosch WKD28350
  • #89875
    Gary59
    Hello,
    I look after a block that has several of the above washer dryers, and the faults are always the dryers failing. Usually cleaning the condensers and re setting the stat trip solves the fault, but I have had some in the past where they have again failed quickly, and changing the stats has still not resolved the problem.The agents have ended up replacing units. Valves checked etc.
    I now have another where again after cleaning has failed very soon after. Any ideas as these do seem problematic. Were they made by Smeg?
    #442827
    aqualectric
    Re: Bosch WKD28350
    Yes it’s a Smeg in drag……. so anything is possible…. 😕
    Usually the thermistor or fan motor jamming or faulty when hot, fan blades full of fluff or earth leak on drier heater. Not much else really.
    Steve.
    #442828
    Gary59
    Re: Bosch WKD28350
    Cheers Steve, yes checked heater, done a few with earth faults , I’ve cleared fluff on these also in the past, so think I will play safe and quote for thermistor and fan unit.
