Evening gents
I have come across this integrated washer/dryer today with an E13 error message. The error appears about 5 seconds after selecting a programme. The interlock solenoids clicks before and after the error code appears.
Conflicting advice suggests it may be a ‘time out’ drainage error or door interlock fault. I have pretty much ruled out the drainage error but can’t fill and test the machine as I can’t get past the error state.
Am I in the right ball park with the interlock before I order it and, if the lock does the trick, will it clear the error state or is there a ‘reset’ procedure.
Many thanks all
Jason 😀
