Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch wm can’t reset
- This topic has 7 replies, 4 voices, and was last updated 9 years, 2 months ago by
pmb.
January 9, 2017 at 9:22 am #90294
pmb
ParticipantHi i have been having fun with a Bosch WAE24063GB/31 which is flashing the rinse light and i can’t work out why. The carbon brushes are at about 70{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} and show no signs of burning on the edge, the motor has continuity through it and the heater is fine. I have tried the reset procedure i found on this site but it didn’t work (turn to position 15 hold start button for 3 secs and turn to pos 3 and release). This machine has been moved to a new position and hasn’t worked since, it has been wedged in so tight i can’t pull it out so i couldn’t check water valves could they cause the rinse light to flash? Thanks in advance
January 9, 2017 at 10:21 am #444295Martin
ParticipantRe: Bosch wm can’t reset
You’re gonna have to get it out. Probably an inlet issue or, more likely, a drain issue. Kinked drain hose?
January 9, 2017 at 3:46 pm #444296pmb
Thanks Martin i was afraid of that
January 9, 2017 at 8:53 pm #444297nomadPaul
Not sure that reset procedure is right though. On most WAE machines , the reset is turn selector switch to the 6 o’clock position , hold the spin speed button and then turn selector switch switch one click clockwise. Release the spin speed button and that should clear it.
January 10, 2017 at 5:39 pm #444298pmb
Thanks Paul, this is a newish machine without a spin button. I found a post on here for that enr that described the reset procedure i mentioned but i couldn’t get to work. i did try the 6 o’clock with all the other buttons
January 10, 2017 at 6:28 pm #444299pmb
Has anyone used the reset procedure i mentioned above? or is there a different one?
January 25, 2017 at 8:20 am #444300pmb
Hi i managed to reset this machine by holding start whilst in the off position moving either one or two positions anticlockwise and releasing. I was literally trying everything i could think of so i wasn’t sure whether it was one or two clicks
January 25, 2017 at 7:32 pm #444301kaibart
ModeratorRe: Bosch wm can’t reset
Hold start and 2clicks to the left is a reset on this model
