Bosch WM not starting
  • #72520
    pmb
    Bosch Washing machine WVD24520gb/08.
    Key symbol flashing, Machine not starting
    Start light stays on (not flashing)
    Door lock stays locked untill power off
    On 01 minute
    Tryed a new lock but still the same.
    Any ideas
    #384769
    Muv
    Re: Bosch WM not starting
    Quite possibly the motor brushes are worn, check these are ok..if not replace..
    If they are not worn,then more than likely a faulty door interlock
    nomadPaul
    pmb wrote:Bosch Washing machine WVD24520gb/08.
    Key symbol flashing, …….Machine not starting
    Any ideas
    I’d be looking to see if the child lock’s been engaged !!!
    #384771
    pmb
    I checked brushes and heater, put a new door lock in.
    I think child lock turns on and off by holding start button for severel seconds. Still the same.
    Might go back and check board connections
    #384772
    jason1970
    Key symbol definitely the child lock! (hold start for 5 seconds to cancel)
    #384773
    pmb wrote:I think child lock turns on and off by holding start button for severel seconds.
    No, no……the child lock is activated and deactivated by pressing the 4th button (Clock icon) under the display panel. Press and hold for 5 secs to switch on or off. Not the start button. 😉
    #384774
    pmb
    I went back today.
    Forth button with clock symbol did not work.
    I have run out of ideas. 😥
    #384775
    pmb wrote:Forth button with clock symbol did not work.:
    Hold up a second….did the key icon not disappear once you pressed that button for 5 secs then? 😕
    #384776
    spanner51
    This bit is in the instruction book
    “The childproof lock must be deactivated before
    making programme changes or ending programmes.
    The childproof lock can only be deactivated if the
    programme for activating the childproof lock has been
    selected. The KEY symbol will continue to flash if a
    different progromme has been selected.
    ? Touch the CLOCK button and hold down (for approx. 5
    seconds) until the KEY symbol goes out.
    ² If there is a power failure, the childproof lock
    remains on.
    HTH
    Graham
    #384777
    pmb
    They don’t have the instruction book.
    Home helps use the machine so it’s hard to know what programme was used.
    It does beep when button pressed after a few seconds but key symbol stays on.
    I will go back and try every programme.
    #384778
    Usually a simple phone call to ask the user just to press and hold the clock button until the key symbol goes out will suffice. And will save you going back a third time! 😉
    #384779
    spanner51
    If you turn the programme selector dial untill the KEY symbol stops flashing, and is on steady, then that should be the ‘selected prog’. Then push and hold the clock button till the KEY symbol goes out.
    HTH
    Graham
