Hi Guys does anybody know what the error code 03 means on this machine had a call to repair it today it would not finish the cycle customer told me their was water in drum so looked for blockages in pump etc Then checked pump motor and impulse paths from PCB. All ok so asume fault is PCB. have not worked on these Machines before so wondered if i was missing something any advice much appreciated Machine 6 years old Serial no E-NR WOK 2001GB/05FD7909 00642
Hi Rob
It basically means it can’t empty for whatever reason.
Check pump, drain hose etc
There is a filter on the front behind flap, check there for debris.
