Bosch won’t wash ( D/W)
  • #93521
    SGV3EO3GB/50
    Drains, starts to fill but in less than a couple of seconds the circulation pump kicks in. Doesn’t seem to let any more water in so consequently just a few weak jets of water from lower spray arm.
    Filled it manually and got full, strong flow so circulation pump is ok.
    Due to strategically placed skirting boards at either end of the plinth I was unable to drag it out. Will return after customer has removed them.
    Apart from usual gunged up matrix, hoses and pressure chamber is there anything else I need to look out for when I return?
    alster
    Re: Bosch won’t wash ( D/W)
    It’s gonna be blocked!!!!!
    #454652
    timdowning
    Access through the front panel with kitchen door off.
    No need to pull it out if it’s just the transfer hose…
