bosch wshing machine trips mains power
Home Forums Public Support Forums Help And Support Washing Machine Help Forum bosch wshing machine trips mains power
  • #80740
    vegman
    my Bosch washine machine classic 1000 WLF2062GB, starts washine ok but about 20 or so minutes later ( not sure of exact time) it has thrown mains power on RCB board. But the spin and drain will work. any anvice on what to do/ what is the cause. Thanks
    #413976
    Re: bosch wshing machine trips mains power
    Check the heater.
    #413977
    vegman
    Hi martin
    Thanks new to this how do i check the heater and where about is it .
    thanks jim
    #413978
    Andy jones
    It needs testing with an insulation tester. If you’re not sure about this it will pay to get an engineer in to sort it
    #413979
    vegman wrote:Hi martin
    With a multimeter or better still an insulation tester. The heater located at the front of the tub, access via removal of the complete front panel. Please don’t ask for step by step instructions as we assume a degree of electro/mechanical knowledge toward anyone asking advice.
    The alternative would be to seek a local independent repair person. Many of which can be found through our ‘engineer search’ facility on the Home page. 💡
    #413980
    vegman
    Thanks that is the best option i think. would you have a rough idea of the cost to call a engineer to test and replace heater, the machine is 12 years old is it coming to the end of its life or can it go on for longer.
    regards and thanks jim
    #413981
    Give a few guys locally a call and ask the question is the way forward I reckon.
