Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WTA-2000
- This topic has 11 replies, 6 voices, and was last updated 22 years, 2 months ago by
Stuart R.
January 20, 2004 at 10:53 pm #5081
Stuart R
ParticipantMy WTA-2000 starting blowing the house fuse so I took it apart and soon discovered that a charcoal thermostat doesn’t work very well and have now replaced it along with the element (just in case!!).
My assistant engineer, aged 3 8O, decided that the nice diagram that I had drawn the wiring down on would make a suitable base for her next masterpiece and now I am at a loss! – I don’t know what colour wire goes where and where the thermostat leads plugs into where and the same goes for the safety switch.
Can any kind person out there help?, I would be most appreciative.
Thanks,
Stuart
January 21, 2004 at 12:56 am #108703Penguin45
ParticipantTerminals i i i i i i i i
W+Br Bu/Bu Bk+Wh/BkHeater i
Bu
ii
R
ii
Bk/Bk
Pull the plug first……………….
Penguin45January 21, 2004 at 7:05 am #108704Stuart R
ParticipantRe: Bosch WTA-2000
Penguin,
A big thanks for this – just a few questions.
I have 3 blues, one dark blue and 2 light blues (these are from the reset switch). Which goes where?
I also have 3 blacks – two from the thermostat and one from the power – again which goes where.
Any advice would be very gratefully received.
Thanks again,
Stuart
January 21, 2004 at 9:15 pm #108705Penguin45
ParticipantStuart,
Terminal block goes:
1 white/brown
2 light blue and dark blue
3 not used
4 black/white and Black (t/stat)Element
Far left pair terminals – black(t’stat) and black from loom
Right pair of terminals – red
Single terminal – blue from reset statPretty diagram I made appears to have got dscombobulated.
Penguin45.January 23, 2004 at 8:26 pm #108706Stuart R
Penguin: you are a COMPLETE star! Worked first time like a dream!
Thank you thank you thank you!
Stuart
January 5, 2005 at 3:39 pm #108707admin
KeymasterRe: Bosch WTA-2000
My dad has sent me to look up wire diagrams for a Bosch WTA 2000 dryer hope you can help
January 5, 2005 at 3:59 pm #108708Martin
Hello all wrote:My dad has sent me to look up wire diagrams for a Bosch WTA 2000 dryer hope you can help
No wiring diagrams available to the general public I’m afraid (for obvious safety reasons) BUT…what’s the problem, maybe we can help? 🙂
January 5, 2005 at 5:45 pm #108709admin
My dad is a qualified engineer not your typical bodger he has done something similar and mearly is after a wire diagram hes fixed the mechanics and just needs to know which wire goes where
January 5, 2005 at 5:49 pm #108710admin
Keymasterits okay i got my dad up and after reading penguin 45’s post he said that was what he needed to know thank you all
March 15, 2005 at 11:30 pm #108711ashridge_mba
My WTA2000 stopped heating and on exmination the heater ring had burned out. I fitted a new one (thanks to Penguin45 for his excellent wiring hints) and whilst it tumbles it still won’t heat. Nothing else seems to be broken. Does anyone have any tips as to where else I should look and the tests I could do. Thanks A_mba
March 16, 2005 at 12:09 am #108712Penguin45
There are three thermostats on the WTA2000 – the “flying lead” stat on the backplate, the safety (or “red button”) thermostat, and the exhaust thermostat in the bottom. All should be normally closed.
Failing that, check the wiring hints above – you may have dropped a stitch.
Strange really – this was the very first thread posted on and it’s come back tol life!
Pull the plug first……………. :plug:
Penguin45.December 24, 2005 at 1:55 am #108713tonysup
Hi ?
Thanks for info sorted thanx look at Mum White Knight Basically the same set up so now running fine and I also have heat>
Thank you again.
Regards.
Tonysup. -
