anyone know if you can get a back bearing repair kit for this dryer,
looks as though the orig bearing is machined on to drum, can you drill of,
cheers ally
You can get a repair kit 2413 092 05591, which is the bush and triangular plate and fittings, but does not include the three legged drum support. This is only available as part of a replacement drum. If it’s worked loose and it’s not too badly worn, you can drill the spider to take M6 bolts and nuts and get it back on that way.
As Chris says, the tripod/spider is not available as a spare part in it’s own right – although it should be! I’ve successfully drilled them off of old drums in the past and attached them with countersunk M6 bolts and nuts. I did e-mail Crosslea to se if they would supply me with some, but they said no – bless ’em! Perhaps the buying power of UKW could have more success.
