Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WTA-2000 Thermostat
- This topic has 7 replies, 6 voices, and was last updated 22 years ago by
ADJenkins.
March 28, 2004 at 12:18 pm #5283
ADJenkins
ParticipantHi All,
Can anyone tell me where I can get hold of (preferable by mail or the web) a thermostat (at least I think that’s what it is) for the Bosch WTA-2000 Tumble Dryer. This is the small ‘stat that’s mounted on the same round back-plate as the element. It looks a bit like a power transistor with only two black wires.Regards,
Andrew Jenkins.March 28, 2004 at 12:38 pm #110349admin
KeymasterRe: Bosch WTA-2000 Thermostat
The part number is 039480 and available from BSH Appliance Care Ltd or from UKW if you contact me direct via email
March 28, 2004 at 12:44 pm #110350Martin
ParticipantRe: Bosch WTA-2000 Thermostat
Anonymous wrote:The part number is 039480 and available from BSH Appliance Care Ltd or from UKW if you contact me direct via email
Whoops, somehow I got logged in as guest Sorry but now you can see my email button below.
March 28, 2004 at 6:45 pm #110351Dave_Conway
Martin wrote:The part number is 039480 and available from BSH Appliance Care Ltd
Just a thought on this, the Bosch WTA2000GB/?? range of dryers are all made by Crosslee, apart from the cosmetics all the parts are available at less than 1/2 the price from there. This particular thermostat is even available as a patttern spare as it fits a huge range of Crosslee made dryers, White Knight, Whirlpool as well as Bosch to name the most popular.
April 5, 2004 at 12:47 pm #110352admin
Did you manage to find the stat? I have a siemens wt21000 with exactly the same problem. I have also been quoted this part no.It wold be good if I can find a pattern one to do the same job,best quote yet is 21.50 +vat +p&p=31.14!!Then Would be greatful if you could post the info to me.
andrew.allan@bt.comApril 5, 2004 at 2:29 pm #110353Martin
Andy Allen,
I have sent you an email regarding this today
October 7, 2017 at 10:56 am #110354bemuzeduk
cheapest Bosch item I could find was £57.89.
but following your advice I found the same part number on Amazon at a fraction of that
WHITE KNIGHT Tumble Dryer INLET THERMOSTAT Cut Out 039480
Sold by: Arktikas Limited £6.88lets hope it is the same item!
October 7, 2017 at 11:13 am #110355electrofix
ModeratorRe: Bosch WTA-2000 Thermostat
you will be ok I would have sent you to
https://shop.ukwhitegoods.co.uk/4213078 … thermostat
these units are built by white knight for Bosch. check element while you have it apart. its a common failure for one element to fail first which only gives you half heat
if you need one
https://shop.ukwhitegoods.co.uk/ps3402- … er-element
