BOSCH WTA 2000 Tumble Dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum BOSCH WTA 2000 Tumble Dryer
  • #71891
    bakershop
    My WTA2000 Bosch Tumble Dryer will not tumble. With no belt attached the motor will not turn. There is a ‘humming’ noise from somewhere, might be a round electrical piece attached to the motor seating bracket. The motor will spin if I give the spindle a twist, when I switch of the power it stops and will not start again without twisting it again. Red light is live and door switch appears to function.
    Your help would be appreciated. Thank you.
    bakershop
    #382706
    Muv
    Re: BOSCH WTA 2000 Tumble Dryer
    The round piece attached to the motor is the “start capacitor” it’s this that kick start the motor in to action… Replace this and you should be up and running again…
    Power off when you remove the old one..and take careful note of the way the wires are attached to the terminals…
    Make sure you replace with the correct value capacitor for your machine ..
    bakershop
    Thank you Muv for your prompt reply. I assume that the ‘start capacitor’ will have its values stamped on it somewhere.
    regards
    bakershop
    #382708
    From memory it should show it as 8 uf. 🙂
    #382709
    bakershop
    The new capacitor was received today, 8uf as Martin suggested. Re. installation. I notice from the old capacitor that the two brown wires go together and the two yellow also. But there is no indication which pair of terminals they are fixed to, i.e. there is no + or – on both old and new. Does it matter please? Any help would be appreciated.
    PB
    #382710
    DrDill
    My god this is basic stuff, you really should know this.
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #382711
    bakershop wrote:The new capacitor was received today, 8uf as Martin suggested. Re. installation. I notice from the old capacitor that the two brown wires go together and the two yellow also. But there is no indication which pair of terminals they are fixed to,
    The capacitor has dual terminals and have no polarity. Just connect the two brown together on one dual terminal and the yellow on the other. 😀
    #382712
    bakershop
    THANK YOU MARTIN. I have fitted the capacitor and it all works fine. Saved me a packet of cash.
    Good wishes
    Bakershop.
    #382713
    bakershop
    Dr Dill
    You have not quite grasped the concept of Forums I think. They are supposed to help.
    #382714
    DrDill
    I say basic because if your not sure of this basic stuff should you be messing with it?
    Sent from my iPhone
    #382715
    bakershop
    Oh I get it now Dr Dill.
    You supply new white goods. You are forgiven.
    #382716
    DrDill
    I have also been fixing appliances for 32 years!
    Sent from my iPhone
