Bosch WTA 2733 dryer
  • #26693
    Wibbly
    This has started making horrible “rubbing/grinding” noises. I suspect the drum bearings are shot.
    I took the top off to ‘have a look’ and wasn’t sure about taking the back off. Tipping the machine seems to have temporaritly improved things a bit, but
    1. Should I consider this repairable. Sounds expensive/perhaps a false economy to try and repair this fairly old machine.
    2. There are a lot of screws holding the back panel on. Looks like it’s not only attached to the machine’s frame on the sides, but also to the rear drum bearing/frame. Is it safe to ‘unscrew the lot’ to get the back off to have a look at the state of the rear drum bearing, or does this model normally fail at the front (if I recall with plastic ball bearings round the front edge of the drum wich fail eventually?)?
    Any advice to getting this sorted would be gratefully received.
    W
    #211088
    Re: Bosch WTA 2733 dryer
    Rear shaft/bearing, belt tension pulley, front drum bearing pads, ripped up tub seal, something trapped, or motor bearings can all make noises.
    Power off if investigating.
    Wibbly
    Thanks. Anyone know about taking the back off/correct dissaembly order?
    #211090
    Wibbly wrote:Thanks. Anyone know about taking the back off/correct dissaembly order?
    Dismantling a dryer such as this is not a complicated procedure. Obviously each and every screw, washer, bracket, pulley, fan, heater plate etc etc will need systematic attention to ensure the reverse is applied when re-assembling. 😉
    #211091
    Wibbly
    Sure.
    Just trying to avoid that sinking feeling of something dropping down inside as I remove some screws on the outside – and wondering how to align everything back up to reassemble it!
    I guess a dryer isn’t likely to be like that though…
