Bosch WTA 3500 Tumble Dryer Door Catch
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WTA 3500 Tumble Dryer Door Catch
  • #35725
    Bad-Dad
    The door catch on my Bosch WTA 3500 is broken, and I can see absolutely no way of seperating the front and back panels of the door in order to fit the replacement part. Can anyone help…..please!
    #247779
    Re: Bosch WTA 3500 Tumble Dryer Door Catch
    Which version…
      WTA3500/01
      WTA3500/02
      WTA3500/04
      WTA3500/06
      WTA3500CH/01
      WTA3500CH/02
      WTA3500CH/04
      WTA3500CH/06
      WTA3500CH/08
      WTA3500FG/01
      WTA3500FG/02
      WTA3500FG/04
      WTA3500FG/06
      WTA3500FG/08
      WTA3500GB/01
      WTA3500GB/02
      WTA3500GB/04
      WTA3500GB/06
      WTA3500GB/08
      WTA3500UC/04
      WTA3500UC/08
      WTA3500UC/10
      WTA3500UC/13
    As you can see there’s a few to choose from. 😉
    Bad-Dad
    So I see!
    Model is WTA3500/GB01
    #247781
    gegsy
    IIRC, the door outer panel should just pop off, if carefully teased away from the inner door 😉
    superfix
    Use a small blade terminal driver to prise the door skin apart.
    You will also need a small torx bit to remove the fixing screws for the hook IIRC it’s a T-15.
    #247783
    Bad-Dad
    Thanks very much – I’ll give that a try.
    #247784
    Bad-Dad
    Brilliant! Thanks to everyone for their advice – I completed the repair for less than £10!
