Bosch WTA 4007GB is it just the belt?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WTA 4007GB is it just the belt?
  • #43659
    wisethebap
    The drum on my dryer wont turn unless I give it ‘a start’. Once it starts turning it goes until it stops to change direction and then it needs a ‘push’ again. Does the belt need replaced or is it something else?
    Hope you can help
    #278038
    cockney steve
    Re: Bosch WTA 4007GB is it just the belt?
    sounds like a motor-capacitor or worn carbon brushes in the motor.
    Do a forum search and you should find all the info. you need to establish your problem……contact “parts” at UK Whitegoods and you’ll get them super-fast 😆
    #278039
    It’s a capacitor start/run motor on this machine. If it runs when you push it off, it almost certainly needs a new capacitor. This is not an available spare on the parts listing – you can have a new motor and capacitor for £161, or you can pull the plug, put the machine on its back, remove the base panel and find the capacitor and tell us the “uf” rating. The Shop@ facility on the task bar on the left will have a matching one.
    8 uf they are. 😉
    #278041
    Thank you, Martin. It’s THIS ONE here, then.
    wisethebap
    Thanks for the help.
    Forgot to add that I can hear the ‘motor’ trying to turn, does the capacitor give a power boost to get the dru going? Also, I think the heater has gone. Any easy way I check this, given that the drum probelm ?
    #278043
    Start with changing the capacitor first to get the drum turning once more. Only a check with a multimeter will tell if the element has gone AWOL? Usually it’s just symptomatic of a duff capacitor in my experience…. 😀
    #278044
    wisethebap
    Thanks again Martin.
    I’ll get a capacitor and see how i goes from there.
    Here’s hoping
    #278045
    cockney steve
    Use a multimeter…..disconnect one side of the heater….measure resistance between the 2 terminals ~25-30 ohms, iirc. higher is likely burnt out. lower would probably be shorted and fail leakage test below.
    then measure either terminal to earth (heater sheath or bracket)….meter shouldn’t move!….digital should be many K-ohms or Megs. anything lower= earth leakage.
    Order your parts altogether from the site shop,I’ll be amazed if they dont hit the doorstep within 24 hours 😀
    I tried adding something 20 minutes later and order hed already been processed!!!!!
    #278046
    wisethebap
    Thanks steve, but they were too quick. The capacitor was dispatched before i’d read your post lol.
    Is there a link that explains the best way to change the capacitor ?
    #278047
    cockney steve
    Just had a look at the flightless one’s reference and it already has 1/4 ” Lucar connectors (in plain english, spade terminals )
    If the wiring harness is already terminated with push-on spades, it’s easy-peasy (just make sure polarity is correct,IF the cap is polarised )
    Any car -spares shop will sell you the appropriate “spades” which can be soldered or crimped to the ends of the wires.
    If there’s not a mounting -bracket for the cap, you can tie-wrap it to secure it.
    (the casing appears to be fully insulated and i get a feeling it is not polarity -sensitive….bung one wire ,from the old one, to one side of the new one, repeat with second wire….fix it so it doesn’t get bashed around, job’s a good’un. 😆
    #278048
    wisethebap
    ty.
    Hate to be pain, but best way to get access is relly what i mean
    #278049
    Post #3………
    cockney steve
    *note to self….read the question properly!* 😳
    The above comments on testing an element, only apply to a sheathed element .
    (looks like a kettle or cooker-element….if yours is the thin-wire type it’ll be fairly obvious.
    Secondly….there will be a safety-stat / stats in series with the heater. Some are self-resetting, when they cool down, others have to be changed if they go open-circuit.
    Don’t make the assumption that no heat = faulty heater…TEST THE CIRCUIT.
    UNPLUG FIRST!
    #278051
    wisethebap
    replaced capacitor, which was ordered from spares and arrived very quickly. Machine working again.
    Thanks for the help much appreciated
    Aww well back to the laundry
