This brilliant dryer has 2 heat settings, only one is working.I have checked the switch which is working fine.I suspect it is probably an element that has gone.I would appreciate any advise also can you tell me that if it is the element is it easy to fit.
THANKS
Re: BOSCH WTA2000 DRYER ONLY ONE HEAT SETTING WORKING
Thank you sir,,are you saying that there are 2 elements, I have just spoken to my son , he tells me it works on the high setting.
I read your other information regarding the reset button but he tells me it doesn’t move at all when he presses it.
cheers
