Bosch wta2000 dryer – rear panel removal
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch wta2000 dryer – rear panel removal
  • #28136
    Boothenangel
    trying to remove the rear panel of my bosch wta2000 to try and find out why it isnt heating anymore. From the posts on here I reckon I need to test the element and 2 stats.
    However, I can’t get the three screws out of the back panel to allow me access to the back of the drum and the element – I’m going to round them off if I do it anymore.
    Am I doing something stupid? Surely they can’t be that hard to get off – they aint even budging a little bit.
    Hol
    #217063
    Re: Bosch wta2000 dryer – rear panel removal
    Boothenangel wrote:Am I doing something stupid? Surely they can’t be that hard to get off – they aint even budging a little bit.
    That’s the 3 screws on the bearing hub you are referring to I guess?
    They are pretty tight as they are put on with a power tool in the factory, so any good cordless screwdriver with a pozidrive bit in it will remove them, no probs!
    All the remaining screws around the back panel will have to be removed as well, but I guess you’ve done that anyway?
    Do make a note of any wires you take off and where they go ‘cos we can’t help you there my friend. 😉
    #217064
    Boothenangel
    Cheers – they are the ones I meant – I just wanted to make sure before i subjected them to brute force 🙂
    Thanks for the speedy reply
    Hol
    (Oh and yes I will be writing it down 😕 )
