I’m having a problem with the dryer not turning the drum.
If I remove the top cover I can start it by giving the drum a push.
Am I correct in thinking this is a fault with the capacitor on the side of the motor? If so is this a replacable part or will I need to buy a new motor. I have checked the drum for tight/worn bearings, no problem found.
