Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WTA2000GB/02
- This topic has 7 replies, 5 voices, and was last updated 17 years, 4 months ago by
rocker.
December 4, 2008 at 9:51 pm #41602
rocker
ParticipantFitted new element today use a whirlpool (cheaper than bosch) on fitting it scrapes after heating up, have taken apart and reset element about 5 times, stiil the same. can anyone please advise, the triangle shape bearing has plenty of movement not sure if this is normal.
john.December 5, 2008 at 12:47 am #270716Penguin45
ParticipantRe: Bosch WTA2000GB/02
Don’t worry about the bearing; it’s only a problem if the spider starts to break away from the back of the drum. It’s a Crosslee/White Knight machine, not a Whirlpool. If you used a pattern element, some of them are pretty shoddy. Masterpart do a decent one, or buy the gen Crosslee one to make sure of a decent fit.
December 5, 2008 at 8:31 am #270717Martin
The 3 fixing mountings need careful alignment (sit squarely in their recesses) and the top edges tapping down closer to the element. Otherwise the squared edges stick out and scrape against the drum. 😉
December 5, 2008 at 3:56 pm #270718rocker
Chris, have fitted a service/ whirlpool element from connect part No WPL481925928745 should this be ok, or would it be better to order the crossley you mentioned, if so have you the part No please. John.
also Martin, thanks for your reply. John
December 5, 2008 at 4:52 pm #270719wilf
look at the element fixing bracket from the side you might see that its not quite 90 degrees you can push it into 90 with a pair of grips. you can if you want lay the element onto the floor and push the top element down slightly near to where it turns into the bracket DO NOT HIT IT WITH A HAMMER.
wilf
December 5, 2008 at 4:58 pm #270720Simon46
I have had to stand on the bracket on some pattern ones to get them to fit. Thicker inner element catches drum in area next to bracket. basically push it away from the drum.
S.
December 5, 2008 at 7:06 pm #270721Penguin45
Gen Whirlpool heater will be the same as the Crosslee one – just three times as expensive!
December 5, 2008 at 7:31 pm #270722rocker
Thanks to all you guys for your advice, well have managed to Refit heater with your help and has now been running for over 30mins, and very quietly. (what a great forum this is) would have been stuck on this one.
cheers again John
