Bosch WTA3000GB Tumble Dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WTA3000GB Tumble Dryer
  • #58323
    mike412
    Hi folks.
    I have received from Bosch part number 182113 start switch assembly, complete with an almost illegible and unintelligable “instruction to fit” sheet and a bundle of wires. I think that I have worked out that you dont need the bundle of wires, they are for a different model perhaps. The old switch is 2 gang, one white pair and one green pair. The new switch is 1 gang, with a seperate micro switch operated by the pecker on the door. Do I assume correctly that the green pair go to the start switch and the white pair go to the microswitch?.
    Any assistance as usual much appreciated.
    Mike
    #334084
    nationalhomecare
    Re: Bosch WTA3000GB Tumble Dryer
    Another BSH conversion for the Whirlpool manufactured dryer. Done one the other week and it don’t work!!
    Sorry I couldn’t be more positive.
    Regards
    Steve
    #334085
    Beever
    U got it! Dont need the wiring they sent. All they have done is moved one of the micro switches. Just connect up the same as it was. The two switches are no longer in the same housing!
    Nice n easy!
