Bosch WTA3100GB/07 Tumble Dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WTA3100GB/07 Tumble Dryer
  • #41227
    mike412
    Hi Folks.
    Went to one of these today timer knob spinning. Have ordered new knob from BSH, will have to go back early next week to fit. My question is…… How on earth does the facia panel come off, (I assume it has to).
    Anybody got anything I can read in bed sunday night?
    Many thanks in anticipation,
    Mike
    #269185
    SWERV
    Re: Bosch WTA3100GB/07 Tumble Dryer
    Hi,this is what Martin was good enough to tell me when I asked the same question.
    Open the door and you’ll see on the underneath of the fascia panel 3 (from memory?) clip cut outs. First ease these lugs upwards and outwards. I use a knife blade between the fascia and front door panel. Likewise a knifeblade at both sides of the fascia once you’ve pushed in the retaining latches (again 3 I recall?) that run along the top of the fascia and under the metal top fixing bracket.
    Basically the whole fascia is just a push fit on reassembly so a bit of TLC with the use of a Swiss Army Knife is all that’s required to lift it off!
    It worked a treat!!
    Merv
    #269186
    mike412
    Thanks Merv, Will give it a go next week.
    Cheers, mike.
