Bosch WTA3204GB/09
  • #16531
    ChrisR
    What`s the normal reason for a `no heat ` fault on this drier?
    Heater checks out ok along with TOC.drier runs ok but no heat or very little.
    Suspect sensor above heater elements???.
    Thanks.
    Beever
    Re: Bosch WTA3204GB/09
    Check the heater ntc on the heater
    #170254
    ChrisR
    Thanks very much Beever……..I`ll try that. 😀
    #170255
    ChrisR
    Hi Beever.
    Theres no black housing and no green stat that I can see.
    Theres a probe situated in the front ducting and that checks out ok.
    Any ideas?.
    #170256
    There is a safety cut-out on top of the heater box which can trip. Every one of these I’ve ever been to has ended up being the computer board………
    Beever
    this appliance is an auto sensing one. if there is no wet load in the appliance, it will switch off within aprox 2 mins. It passes a current through the laundry, this charge is then picked up between the tank and the paddles, the drum and the paddles can get coated with a coating of softener, give the tub and paddles a clean to ensure that the charge is being detected.
    #170258
    ChrisR
    Thanks guys for the help.
