Bosch WTA3204GB/09 Dryer, no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WTA3204GB/09 Dryer, no heat
  • #34740
    bagman
    Haven’t spent a lot of time on these, so would like some idea’s before I start digging a hole for myself.
    Heater and reset stat both checked ok.
    When I set the dryer to any program, the heater comes on for about 30 seconds, then goes off never to come back on again.
    I suspect PCB/Thermistor but would like to hear from someone who has worked on these more if possible..
    Thanks in advance.
    Trev
    #243845
    bagman
    Re: Bosch WTA3204GB/09 Dryer, no heat
    Btw, I’m not the first, http://www.ukwhitegoods.co.uk/modules.p … t=wta+3204
    But still no answer really. 🙁
    #243846
    Being as these are sensor dryers, testing without a damp washload causes all sorts of problems. The brush pick-up senses no resistance and therefore the heat shuts down anyway. So start with one damp towel in there at least! 😉
    #243847
    gegsy
    It would turn for at least 2 mins before aborting with no damp load or drum sensor fault as Martin said 😀
    Make sure the airflow circuit is clear and filter is clear 😀
    Heater is only activated when the drum turns in a clockwise direction and when working temp is reached on one NTC, it will turn off the heater for 2 mins.
    IMHO I would say NTC/S out of tolerance, turning heater off too soon if airflow as above is ok.
    bagman
    Thanks, I have tested with load and the airflow is clear, so I’ll go for the ntc then.
    Cheers guys 🙂
