Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WTA3204gb09 T/D
- This topic has 7 replies, 2 voices, and was last updated 17 years, 4 months ago by
Steven.
December 8, 2008 at 4:25 pm #41691
Steven
Participantjust put this on the forum but cant see it, so doing it again.
Called on this Bosch tumble dryer 2 days ago for a noisy jockey pulley.
Now c/x complaining not heating properly.
Only heats for a short time on one way action, when it goes the other way the heat stops any suggestions.?
Steven
December 9, 2008 at 8:33 am #271011Martin
ParticipantRe: Bosch WTA3204gb09 T/D
Carbon brush pick-up at the back of drum and on the drum not making properly? Airflow problem with TOC tripped?
December 9, 2008 at 9:07 am #271012Steven
Both carbon brushes are making contact and are not worn much.
Airflow fine does has not even trip off cut out stat.
Seems strange that it heats on the shortist reverse then when switches to the main long tumble the heat relay clicks off.
The heater relay has some burn marks on the cover?
c/x after did say it has been taking slightly longer to dry.
What are the resistance readings on the sensors?
Appears to be a pcb fault? wanted to confirm b4 committing.
December 9, 2008 at 12:21 pm #271013Martin
Steven wrote:Seems strange that it heats on the shortist reverse then when switches to the main long tumble the heat relay clicks off.
Well it should switch off on the 5 second reverse so that indicates the module is at fault I would assume?
Steven wrote:The heater relay has some burn marks on the cover?
It’s not looking good for the module and I too would have my suspicions based on those two factors. HTH?
December 9, 2008 at 12:42 pm #271014Steven
Yes thought it would be that, but needed to confirm.
Thanks for your help.While you answered this one did you see my other one about the bosch sensadry fault in this forum ?
Steven
January 12, 2009 at 12:10 pm #271015Steven
Ordered a new board and heater sensor from BSH.
Still having exactly the same fault.
There is very little on this tumble dryer, 2 stats, heater, pcb.
So unless the pcb is faultly, I noticed box was not sealed and the part in the box is older than the one coming off and it has been mentioned on the site that parts have been coming through used or faulty?
Any other suggestions, want to try and locate this fault any other help would be appreciated.
This is a sensor type are there any problems with the selector operating module switch behind the facia?Steven
January 12, 2009 at 1:01 pm #271016Martin
Steven wrote:There is very little on this tumble dryer, 2 stats, heater, pcb.
I’m sorry to hear the new PCB didn’t cure the problem. 🙁
By “2 stats” I guess you refer to the overheat stat on the element and the NTC in the door ducting. So my next question is: have you got a reading from the NTC to suggest it’s functioning OK?
January 12, 2009 at 1:37 pm #271017Steven
Both stats have a reading, the sensor below the door reads ok and the ntc on the heater (which i have replaced), not sure if its within the limits as no tech info!!
Cheers
Steven -
