Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Bosch WTA4007GB/03 tumble dryer belt
- This topic has 7 replies, 4 voices, and was last updated 13 years, 4 months ago by
ronst.
December 1, 2012 at 12:26 pm #72815
ronst
ParticipantThe belt in my tumble dryer is broken, so I looked on line for a replacement and found that the 1930H belt would bit.
So after 2 hours struggling I had the belt in the machine, but it looks like it is to big.
I don’t see a Tension pully/arm, it is just straight to the motor, which is a bit weird.
Does anybody know where the tensio pulley is located in this tumbledryer, if you can make a picture that would be very helpfullCheers
December 1, 2012 at 1:07 pm #385649Muv
ParticipantRe: Bosch WTA4007GB/03 tumble dryer belt
There should be a double tension pulley directly underneath the drum..
Belt should rest on the inner part of one wheel, then around motor shaft, and back to rest on inner part of remaining pulley wheel.. This pulley assembly then provides the necesarry tension..check that the spring in pulley assembly is intact,before fitting..Martin
December 1, 2012 at 2:57 pm #385650Martin
ronst wrote:, if you can make a picture that would be very helpfull
Item number 0411 in the picture below……December 1, 2012 at 4:32 pm #385651ronst
Thanks Martin,
I will have a look if I can find this.Ron
December 2, 2012 at 11:35 am #385652ronst
I had a look and there is no tension pulley in my tumble dryer
Maybe this tension pully only in the models WTA4007/01 and /02 and not in the /03?
It looks to me that my new belt (1930H) is a bit to long, because there is no tension pulley.
On my old broken belt, I see something like EPH 1906, does anybody if this a model number for this machine ?Any help is welcome
Cheers
RonDecember 2, 2012 at 12:58 pm #385653repman
BSH446856 is part number for your belt eph1906
jim
December 2, 2012 at 1:28 pm #385654Martin
December 3, 2012 at 7:01 am #385655ronst
I have ordered the other belt, hope fully it arrives this week, I will then let you know in weekend if it fits.
Cheers
