Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › bosch wta4108gb/03 tfitting new belt help
- This topic has 7 replies, 3 voices, and was last updated 15 years, 2 months ago by
robti.
January 13, 2011 at 4:32 pm #60170
robti
ParticipantHi
i have ordered a new belt for the above and am loooking for some help on how to fit it.
Any tips?
Robert
January 15, 2011 at 2:01 pm #340966robti
ParticipantRe: bosch wta4108gb/03 tfitting new belt help
Okay got it fitted but its around 1″ too long.
any help ?Robert
January 16, 2011 at 8:33 am #340967Martin
Order the correct belt then from Bosch (Part No: 446856)
January 16, 2011 at 11:24 am #340968quickwash
:waving: martin, you have got a naughty streak this morning :snig: 😉 .
I like a bit of good ‘clean fun’ :rolls: to give us all a lift on this dull old day 😀
best wishes to you and good luck to robti with his belt
quickwash :plug:
January 16, 2011 at 8:09 pm #340969robti
Thanks for the helpfull replies :rolls:
Just for anyone in the same situation ordered the replacement belt from the spares shop on here and it was the correct one for my model no. but after a few e-mails to Dave found out that i may have the 4 model and not the 3 as on the ticket, so re-ordering a replacement
Robert
January 17, 2011 at 8:13 am #340970Martin
robti wrote:i may have the 4 model and not the 3 as on the ticket, so re-ordering a replacement
The WTA4108GB/03 & WTA4108GB/04 both have the same sized belt (Bosch Part No: 446856)
January 17, 2011 at 11:30 am #340971robti
ParticipantMartin wrote:
robti wrote:
i may have the 4 model and not the 3 as on the ticket, so re-ordering a replacementThe WTA4108GB/03 & WTA4108GB/04 both have the same sized belt (Bosch Part No: 446856)
Thanks for the reply, but the label on the machine shows the /03 model which has a belt with the no. on it EPH-1906.
Now ordered off the UKWG shop and recieved a belt with 1930 on it which should have been the correct one for that model of machine.
Now the replacement belt is approx 1″ too long so i equate the numbers on the belt too length and the 30mm extra would be the 1″ approx too long.
So contacted Dave who advised me to order the shorter belt from the /04 model which has the 1903 stamped on it.
So as i am not an expert in this i can only assume i got a late /03 model with a /04 drum
no.s from ukwg shop
http://shop.ukwhitegoods.co.uk/Tumble+D … +Belt.html
As you can see not thye same so i could only follow whats info i had
Robert
January 23, 2011 at 6:30 pm #340972robti
Got the shorter belt and perfect fit 😀
Robert
