Bosch WTA74200GB/01
  • #88450
    chitts
    I have a customer whose dryer dries perfectly 1st load and then cuts out after a few minutes on any other tries until next day, when same thing occurs. As it’s a vented dryer I’ve checked for blockages and bad connections, but nothing obvious. Just hoping someone may have had similar problem.
    #438133
    Re: Bosch WTA74200GB/01
    Youv’e just got to hope it is the NTC on the heater box otherwise it could be main PCB woes. You’ll need a soldering iron to fit the new NTC if I recall correctly.
    #438134
    chitts
    Thanks. I can go prepared.
    #438135
    keithwilliams
    can i jump in here? my customer will abort any heated cycle so i have suspected the ntc. can you tell me what the room temp value of this is lease, or better still exactly which one youd recommend.
    many thanks
    k
    #438136
    grooster
    Sorry to bump an old thread but I’ve got what seems to be the same problem on the same model here. It initially gets nice and hot then gradually gets cooler and cooler with time. No blockages etc. Is it the NTC on the heater or is there another stat somewhere else that causes it? Can you buy the NTC separately.
    #438137
