Bosch wtb86300gb error E90
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch wtb86300gb error E90
  • #95284
    Andrew Watson
    I have the above fault on my dryer. Any pointers? It seemed to stop for high temp. I’ve checked the thermal fuse on the heater duct- continuity o. I haven’t checked what might be a thermistor that’s mounted next to it.
    When I trg to start the dryer there is 5 or so cycles of clicks from the control unit up on the top rhs then it alarms.
    Any ideas?
    #459895
    Andrew Watson
    Continuity ok it should say.
    #459896
    Paulina
    Did you get this resolved, I have exactly the same problem and tested lots of the probable causes.
    Exact same fault – On startup a relay clicks 5 times which surges the lift pump each time. Then displays E90 which is a communication error.
    I have replaced the lift pump, checked continuity on the pump and level sensor cables. Removed control board and re-coupled all connectors. Checked heater element. Cleaned both lint and moisture sensors.
    At my wits end now, last chance is to try swapping the control board, but they are not cheap, so may be better just replacing with a new machine. 🙁
    #459897
    Bigmac85
    Did you manage to resolve this Paulina? I just got the same error.
    #459898
    Thien Chau Qui
    Hi, I dried the power board and reconnected all the cables. If the motor cable is removed, it will give e90 for me. So make sure you reseat the motor cable properly
