Re: Bosch WTE5820gb/04 Condensing TD
Best way
1/ Lid off
2/ Undo torx screws that hold r/h panel on behind filter flap/grill at front
3/ Undo torx screws at rear that hold the r/h panel on.
4/ Undo screws on top of r/h side panel IIRC
5/ Once all that is done, the panel should lift up ward and off with a bit of persuasion.
6/ You now have access
7/ Remove small belt and tension jockey arm
8/ You can now gain access to uplift bath assembly, rest is apparent 😀
HTH
