I have an issue with a bosch wte6920gb intergrated condenser dryer it is working ok but there is condensation building up under the machine and in front of the condenser when in use ,any ideas what could be causing this issue i have checked all the pipes and pump and no blockages
thanks in advance
georgefry wrote:but there is condensation building up under the machine and in front of the condenser when in use
Condensation is a big issue at this time of year especially when you have restricted ventilation behind the kitchen cabinets and against an outside wall. Check also if there are old vented dryer outlets that are not sealed directly behind the machine.
