Hi, This dryer has a worn intermediate belt(154142). Not having changed one before, I wondered if anyone has any pointers in the best plan of attack! Does the motor slide out to the front or is it front, back, drum out and split the chassis? :eeek:
Heater backplate off, remove front fan, disconnect belt tensioner spring, release motor plastic retaining bracket and withdraw motor through the back. Reassemble in reverse, remembering to fit intermediate onto shaft as you slide the motor back into position. 10 minute job overall….. 😉
