Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WTE6920GB/04
- This topic has 7 replies, 3 voices, and was last updated 16 years, 11 months ago by
MrTwintub.
April 22, 2009 at 10:23 am #45153
MrTwintub
ParticipantHi all, I wonder if anyone can help with the problem on this machine.
Customer says that it trips the circuit breaker when it has been running for a while, however I have not had this happen when testing it. BUT I noticed that the machine does not reverse, it turns, stops, then turns the same direction again. Customer admits to having had a look but swears every thing went back where it was.
Is this a likely PCB fault or more likely a wire misplaced. If the latter would anyone have a wiring diagram.Thanks
Andy
April 22, 2009 at 11:13 am #283840Martin
ParticipantRe: Bosch WTE6920GB/04
I would imagine that the power module was the reason the motor didn’t reverse, relay on board type fault I guess? As for blowing trip after a while is concerned I would look carefully at the element? The scary bit is that you mentioned that the customer had fiddled with it?….scary!
April 22, 2009 at 3:42 pm #283841MrTwintub
Thanks for the reply Martin, Normally I would run a mile but times are quiet.
😳 Just found out that this machine only turns in one direction. 😳
April 22, 2009 at 3:47 pm #283842Martin
MrTwintub wrote: 😳 Just found out that this machine only turns in one direction. 😳
Yeah you said earlier, one direction so not reversing, got you the first time. 😉
Check the Module if I were you?
April 22, 2009 at 5:12 pm #283843MrTwintub
You misunderstood my 2nd post. 😉According to Bosch this machine only turns in one direction because it is designed to only turn in one direction.
April 22, 2009 at 5:22 pm #283844Specialist01269
No wonder it had you stumped, looking for a logical reason for a fault when there isn’t 1, don’t you just love customer fault reports ? 😆
April 23, 2009 at 7:59 am #283845Martin
MrTwintub wrote:According to Bosch this machine only turns in one direction because it is designed to only turn in one direction.
News to me I thought all Bosch dryers reversed………are you sure that’s right? 😕
April 23, 2009 at 12:39 pm #283846MrTwintub
Well it was news to me as well. 😮 Information came directly from Bosch, so I hope that it’s right.
