Bosch WTE6920GB condenser dryer drum not rotating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch WTE6920GB condenser dryer drum not rotating
  • #75224
    simonig10
    Our T/D has suddenly stopped working. The lights at the front show the timer counting down but there is no drum movement or heat. I have removed covers and checked the heater thermostat which meters okay. Am I right in thinking there will be no heat till it detects the motor/fan running? The motor appears silent with no humming etc. Belt is totally fine. How can I measure voltage to the motor as there are multiple connections. Also is it likely to be the start capacitor? The door switch is fine as I can see that working from the control panel. I have tried rotating the drum as wondered if it was brushes etc but nothing.
    Any help much appreciated.
    #394274
    Re: Bosch WTE6920GB condenser dryer drum not rotating
    a lot of tumble dryers wont turn the heater on till the motor is running and there are damp clothes in the drum
    cant say why motor is not working but if you have an ohm meter you can check for continuity between all connections with motor disconnected
    Specialist01269
    While you have it apart, pull the Motor brushes & check them. May be something as simple as that.
    #394276
    Does this tumble dryer have a brush gear motor?
    #394277
    simonig10
    I have feeling it doesn’t. With the motor seeming completely dead if fear the worst. Time to look for a new one I think given the price of a new motor. I cant easily see how you get the motor out.
    #394278
    Motor failures on any make of tumble dryer are not a common fault TBH. The motor,wiring and controls need checking with suitable test equipment first. To contemplate a new motor or dryer without doing this is not very sensible.
    #394279
    Specialist01269
    Sorry: When I punched the Model number of your machine into a search engine, I got a listing for motor brushes for it.
    #394280
    could be as simple as a badly soldered relay on the pcb
