Bosch WTE84037GB not turning under load
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch WTE84037GB not turning under load
  • #93674
    timintheshed
    I recently replaced the broken belt on a friend’s Bosch WTE84037GB tumble drier. Span it up after the repair and all seemed good. However, the owner now reports that it only starts tumbling when a small load (a few clothes for example) is in it. A wet bath towel is too much and it won’t start.
    The cause of the original belt breaking was drying a pair of curtains with sewn in curtain rings. One of these jammed between the drum and the tub, preventing the drum rotating and the belt to break. I’m not sure if this is linked to the current problem though.
    My (uneducated) guess is the motor start capacitor is U/S. Is that a reasonable assumption?
    #455212
    Re: Bosch WTE84037GB not turning under load
    well normally I would say yes as it fits the symptoms but they had no problem before the belt failed so I would not expect it to fail suddenly
    where was the ring jammed and has I moved the seal making the drum tighter ?
