Bosch WTE84102GB Condenser Dryer Fault Lights
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch WTE84102GB Condenser Dryer Fault Lights
  • #86924
    Matthew@Newlife
    Hello
    Having some issues with this machine, its a Bosch ClassiXX WTE84102GB/03 Condenser Dryer. I have the 1st(DRY), 2nd(IRON DRY) and 4th(ANTI CREASE/END) lights flashing. This was happening intermittently but if left for an hour then it would work fine, unfortunately now the lights are flashing and i cant do anything. I have tried finding the fault codes but nothing matches my light sequence. Any help and advise would be greatly appreciated.
    thanks
    Matt
    #433413
    Re: Bosch WTE84102GB Condenser Dryer Fault Lights
    Take out and clean thoroughly the condenser/air cooler unit and ensure the lint filter and ducting from it are clean.
    #433414
    ihameed54
    Martin if the condenser is dirty does it not have it’s own light called FILTER? Why these sequence of lights for something that has it’s own fault light? I ask because I am having the same issue but my precursor situation was different: I had clicking sounds and the dryer would start and stop in fits.
    #433415
    since this post is 2015 and Martin does not come on forum as much these days you may wait a while for reply
