would appreciate thoughts on source of this fault on my tumble dryer (FD 9712).
The only programme that works is the Easy-Care Extra Dry (11 o’clock position). Turning the control to the Cottons Extra Dry (1 o’clock position) results in a single beep.
This model doesn’t have a digital display so no fault codes. LEDs not obviously flashing any codes.
for the setting that does work, drum rotates, it’s heating and condensate is being produced. The filter is clean, condensate tank empty and moisture sensor is clean. I’ve also plugged it into a different socket.
Is this likely to be a result of a faulty control board?
