Bosch WTE84107GB/02 Condensor Tumble Dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WTE84107GB/02 Condensor Tumble Dryer
Viewing 15 posts - 1 through 15 (of 17 total)
  • #50383
    mike412
    Hi Folks.
    Could someone enlighten me on how the side panels come off on this?.
    I need to check float/pump etc.
    Many Thanks Mike.
    PS posted this in public forum by mistake- might need zapping.
    #304647
    lee8
    Re: Bosch WTE84107GB/02 Condensor Tumble Dryer
    If you cannot work that out, should you be looking inside the appliance ?
    #304648
    mike412
    Better give it up and find something else to do then.
    38years in the trade was a waste of time.
    Mike
    #304649
    BobHope
    Hi Mike
    pm me an email address and i will send you some info.
    im sure lee is been a bit sarcastic and not meaning to be rude, we all get stuck from time to time on somthing that we have not seen before.
    but it is quite easy but only when you have the info.
    Bob.
    #304650
    nomadPaul
    lid off – screws out of rear and top of panel – drop down front base panel to reveal 2 lower front screws then lift the panel as the front edge is located on some pins.
    EDIT : Mike…..what i wrote above is complete Tosh. Thought it was an earlier model. Check your PM’s for correct access
    #304651
    lee8 wrote:If you cannot work that out, should you be looking inside the appliance ?
    The man who declares that he won’t post advice, posts advice.
    Well done and thank you.
    lee8
    I thought it was sensible.
    If you cannot work out how to remove the side panel what chance have you when you get inside of removing the components. :rolls:
    I`ve never in all my yrs been instructed on how to remove panels. 😉
    Sorry if it upsets people, but I`d be worried if I took my car to a garage who did not know how to open the bonnet. 😯
    #304653
    lee8
    I don`t mean to cause offense.
    #304654
    lee8 wrote:I don`t mean to cause offense.
    Like all your other vast array of skills I guess it just comes naturally to you. :rolls:
    No one knows all the answers and the very essence of UKWG’s is the ability to ask questions of ones peers and ‘hopefully’ get a constructive response.
    #304655
    lee8
    I suppose removing panels could be difficult and technically challenging.
    So I`ll help you.
    â–º Remove worktop.
    â–º Remove fascia
    â–º Remove screws A
    â–º Unlock side panel at the rear and pull out of the front holders.
    I cannot copy the picture from the service main frame page, Screws A are down the rear and along the top.
    Front holders are located at the front.
    #304656
    You can stop digging the hole now Lee. 😉 😀
    #304657
    lee8 wrote:I suppose removing panels could be difficult and technically challenging.
    So I`ll help you.
    â–º Remove worktop.
    â–º Remove fascia
    â–º Remove screws A
    There we are, now that didn’t hurt did it ( apart from the sarcastic dig at the beginning).
    I’m willing to bet that most engineers with any length of service will have come across a machine that they couldn’t get into without specialist knowledge, a manual or a crowbar. 😀
    Take the small Hotpoint/Creda tumble dryer cabinet removal. Fortunately I have the manual but how many people had a head scratching moment before finding the tiny screw behind the timer knob has to be removed to get the cabinet off. 😉
    #304658
    Jonah
    I vividly remember it well iadom, an embarrasing few minutes in front of the machine and the customer scrathing ones bonce until I figured it out, I was only just out of my apprenticship though ……… 😳
    #304659
    i remember going to an 18 series hotpoint and the customer had to tell me how to get into the front panel
    was that long ago when hotpoint used a module and pmc to control the motor
    we all have our bad day where we cant see the wood for the trees
    lee8
    Maybe I`m having a bad day.
    I was up most of last night with temperature and Ebola symptoms.
    But I still for the life of me cannot understand why removing a dryers side panel warrants asking on here.
    There isn`t a day that goes by that I don`t have an appliance I`ve never worked on before.
    I changed a cooling fan today on a Kenwood range cooker, never done that before.
    But lids and panels, there isn`t really many places to put fixings, there either on the top, front, side or bottom. :rolls:
    I`m sure others agree with me, they just don`t believe it warrants comment or abuse back.
