Re: Bosch WTE84107GB/02 – Error Codes
Hi all
Still looking for any information available if possible.
I went and saw the machine today, the error comes up on all cycles a couple of seconds after pressing start, I have had a check round all the components and got readings of:
Rear NTC: 25K Ohm
Front NTC: 14K Ohm
Motor: 19 Ohm
Heater OK (Insulation resistance started at 3M Ohm on this but rose to 300M Ohm after removing the tangled in lint)
Pump: 120 Ohm
Float Switch: OK
Door Switch: OK
Safety Stat: OK
Damp Sensor Bars: OK
Start Capacitor 7.5uF
Where ever possible I took the readings from the board end, I have also visually inspected the board but can’t see any problems yet the error code is still there – the error code is lights 1, 2 and 4 (going from top).
Any help before I condemn the PCB is much appreciated.
Thank you
Jem
P.S. Just wondered whether it might need some kind of reset routine after sorting out the insulation?
