❓ the appliance runs for about 5 mins then the filter light comes on, filter, condenser, pump all been cleared out, appliance completely cleared off all fluff yet it still brings the light on , any ideas please
you may have checked this but sometimes the door filters look clear but if you hold them under the tap and try and run water through them they are not?
ill try and find more info as to that light coming on may be a faulty ntc?
Hello again,
Ok the ntc is situated behind the air vent on the bottom right hand side to get the cover open panel for the condenser and then lean appliance back and you’ll find 3 plastic clips to release it you need to be pulling on it also for it to move behind that panel is the filter ntc
Resistances:- 32k at 0c
10k at 25c
0.69k at 100c
Part number 154166 there around a tenner
Good luck
