Bosch WTE84306B/24
  • #101769
    rocker
    I was called to this dryer after customer complaining it wasn’t drying properly, on removed the heat exchanger and filter it was obvious it has never been cleaned, all were totally blocked up, I washed all parts and internal water ways…I left for customer to try out…got a call next day telling me is still not drying as it used to.. there are two NTC one on heat elements and on air flow..I don’t know the values ?? would this cause this problem.. cheers John
    #485991
    have you checked the cold air fan
    ask the customer if its hot and steamy or cold
    rocker
    Already checked not hot and steamy..they feel its not as dry as it used to be.?
    #485993
    have you had a look at the element. if its been that blocked the elements may have sagged and be heating unevenly
    no values on ntc’s little or no tech info for these
    rocker
    cheers Dave..will check that out.
    #485995
    kaibart
    May also be worth checking the from fan isn’t clog with fluff to
    #485996
    rocker
    Cheers Kailbart. Will check that out as well. John
