Re: Bosch WTE84306GB/27 goes dead.
well you could check if the safety stat does shut it down by disconnecting 1 wire and see if machine still comes on
there are some posts about the forum that site earth faults on elements to lack of display on some makes of machine. Have you tried to look for earth faults or disconnect td element when it is in an off state ?
As for the board you can check for blown caps. If you have the ability you can check the power output from the board power supply to see if its a board power supply problem. the trouble is you have to have it in an off state
I take it if you just turn the machine on without starting a programme it wont fail
