Bosch WTE84307GB-05 tumble dryer seals
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch WTE84307GB-05 tumble dryer seals
  • #87120
    greengrass1000
    Hi all.
    Water seems to be leaking from the front of the condenser unit.
    It drips down the cover hinges and onto the floor.
    After hours of investigation, all I can think is that the seals of the condenser are not working and it is running forward.
    So far;
    Cleaned all pipes.
    Taken out pump and cleaned.
    Emptied sump area and removed lint.
    Taken back heater housing off, to remove lint.
    Cleaned sensors removing dirt etc.
    Cleaned condenser
    Cleaned front filter (under door).
    Clothes are drying.
    Water is gathering in top tray/container as should.
    Pump can be heard working, and not noisy.
    Heater elements are working.
    Hot air blowing across condenser (side wards through condenser fins).
    Air being sucked in through front air duct.
    I think I have pretty much done everything I can try, so would really appreciate some advice as to what else I can do.
    Thank you in advance for any comments :con:
    #434011
    stevebunyan
    Re: Bosch WTE84307GB-05 tumble dryer seals
    Is the dryer sat on the floor level, not tilted forward. you could try raising the two frt feet
