Sometimes when start button pressed the drum judders going round in inch movements, other times it just works ok. No loose connections that I can find.
D’ya reckon the PCB is on the way out?
Rob
robbra wrote:D’ya reckon the PCB is on the way out?
Could be though I wonder first whether the power to the motor goes on and off in time to the juddering? And also if you give the PCB a clout will that cure the symptoms?
